victorsevink Posted December 19, 2013 Share Posted December 19, 2013 Hey guys, I use my Pod HD Pro for live gigging alot and i have a slight delay when changing presets via a MIDI footswitch wich is unfortunate. Now my question is: Will the preset changing be faster if i use a line 6 FBV pedal via the Ethernet port instead of MIDI? Thanks, Victor. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 19, 2013 Share Posted December 19, 2013 have you updated your pod to the latest? I'd do that first. I'm not sure how much different of an experience you'd have with the floorboard, seeing as how you'd need a direct comparison.... i'd pick one up and try it... you'll probably have some time when you could return it if its no better. Quote Link to comment Share on other sites More sharing options...
HDProJohn Posted December 19, 2013 Share Posted December 19, 2013 My last group had our guitar processors automatically change patches using MIDI from a DAW live. It was pretty much the same time delay as using the L6 floorboard. Quote Link to comment Share on other sites More sharing options...
AndyParedesMusic Posted December 20, 2013 Share Posted December 20, 2013 if you have a number of time-based effects running on each patch that could be where the "load time" is coming into play and causing a slight delay between presets. Perhaps dialing back on the effects (especially long reverbs) may help shorten the time? would be an interesting experiment to see if it helps. I haven't noticed any problems for my applications when having a MIDI controlled xt or HD500X syncing with a Pro Tools rig (for video), but I don't use a lot of effects. BTW: the FBV also send MIDI CCs (over the Ethernet cable) from what I was told back in CS training - so the message is the same, just the messanger is changing. As Zap said, the only way to know for sure is to try it. Quote Link to comment Share on other sites More sharing options...
