chrisbowsman Posted April 28, 2019 Share Posted April 28, 2019 Hi. I just purchased a used POD XT Live. The pedal wouldn't return to zero for the wah or volume. I found instructions on calibrating it, went through the process, and all was well. Once I rock the pedal three or four times, it goes back to returning to between 14 and 20 with the heel all the way back. Repeated the process several times, same thing every time. I took off the bottom cover, cleaned some dust off the board, made no difference. Any ideas? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted April 29, 2019 Share Posted April 29, 2019 The instructions I have are: Power off Put petal to toe position Hold down Bank Up and power up. Wait a few seconds Press the Amp button Pedal to heel position, then all the way forward until the Wah light turns on Wait 10 seconds, then power off. Power on. If that doesn't work, reflash your memory using Line6 Monkey and retry. Quote Link to comment Share on other sites More sharing options...
chrisbowsman Posted April 29, 2019 Author Share Posted April 29, 2019 I've done all that multiple times EXCEPT the reflash. Still trying to find the appropriate USB cable. The calibration process works, but after a few times of rocking the pedal, it goes back to the same condition where heel back isn't zero. Quote Link to comment Share on other sites More sharing options...
