StephenJJones56
Min and Max in Volume Block
Can someone explain to me what the min position and max position control in the Volume Block. Are they only useful with a foot pedal?  Is it a useful block to adjust the volume without changing my tone?
I am trying to adjust the volume levels of the presets so that they are consistent, but I am not sure if I should do this on the amp block or the volume block?
Cheers
Stephen J
If you assign the expression pedal (or an external expression pedal) to an effect parameter, the sliders are used to set the minimum and maximum limits of the effect. Otherwise, the sliders have no function.
