Using POD HD500X to launch MIDI clips in Ableton Live 10
By
kakarontzas, in POD HD
1 hour ago, hurghanico said:
In the Appendix - MIDI section of the downloadable advanced guide it is written:
"POD HD500 additionally includes the ability to function as MIDI Controller device, with its footswitches and Expression Pedals capable of sending customized MIDI commands."
There is also a specific paragraph "Using POD HD500 as a MIDI Controller Device" which gives detailed instructions.
So, from within specific patches programmed to send customized MIDI commands it is possible to do what you need to do.
On youtube you can easily find some video tutorials about using the HD500 as a MIDI controller for Ableton.
_______________________________________________________________________________________________________________________________________________________________________
Thanks.
I figured it out and also found this tutorial from YouTube which is simple and informative:
However, I was hoping to pass Midi signals from pod to laptop directly through USB. I found out that I cannot do that. So I need to also have some midi in to midi out cable to connect to my audio interface (Focusrite 6i6) and then pass the midi signals from the audio interface to laptop (or so I understood). I have to try all this when I have the right cables, but in principle yes it is doable without an additional midi controller.
Thanks anyway,
Best regards
George
