ishikakhanna Posted August 6, 2019 Share Posted August 6, 2019 Hello. as the title suggests, please ask if you can feed the pocked pod with the voodoo lab pedal power 2 plus. Thank you. https://tobefrankmagazine.com/how-to-fix-pii_email_3da6f7f92016ac861201-error-100-fix/ https://alltechbest.com/how-to-solve-error-pii_email_37f47c404649338129d6/ Quote Link to comment Share on other sites More sharing options...
daveny5 Posted August 6, 2019 Share Posted August 6, 2019 I believe you can, however, you have to make sure you have the correct cable. The Pocket Pod is 9v DC with the Tip (center) being Negative. The outer ring is called the barrel. Make sure you have the polarity correct or you could damage the Pod. According to the Voodoo Labs manual: Almost all guitar pedal effects use a center negative barrel jack for power. This is considered standard polarity. Barrel jacks wired for center positive are considered reversed polarity. You can power reversed polarity effects with a Pedal Power by using the correct reversed polarity cable. It doesn’t matter that the effect is negative ground or positive ground, both types can be wired for either polarity. The black barrel cables included with your Pedal Power 2 Plus are standard polarity center negative. The 3.5mm mini plug is tip positive, which is also standard for pedals which use this connector. I find that last sentence confusing so be sure to read your manual carefully before plugging it in. Quote Link to comment Share on other sites More sharing options...
