assign expression pedal
whizzkid3
I just can't figure this out.  I assigned the level of "simple EQ" to EXP 2.  This gives me an effective boost.
I have the wah assigned to EXP 1.  The touble is, when I engage the wah the level of the simple EQ is at max because to get there I have press EXP2 all the way down to click the switch.  How do I get the EQ to set to a minimum parameter of level when I engage the wah, but function as a boost when not engaged?
This is not exactly what you are looking for but may be enough info for you to set up what you are going for. It is a template I put up in CustomTone a while back that demonstrates how you can activate a wah with a footswitch instead of the expression pedal switch. This allows you to leave the volume level on the expression pedal wherever you want without having it max out when you go to the wah. There is also a link in the CustomTone description if you want to see the steps for creating it explicitly spelled out. You may find it applicable.
CustomTone template:   https://line6.com/customtone/tone/4397153/
