sgouros Posted May 18, 2013 Share Posted May 18, 2013 Hello everybody I really like the specs of G30 but I plan on using it in a different setup. What I need, is a wireless system that takes line level signal as input.This way I can feed my self-powered speakers from my mixer wirelessly - at least one of them :-) My proposed setup so far: [MIXER] OUT 1/4 unbalanced jack ----cable----- 1/4 unbalanced jack IN [Fame DI-120 which attenuates and balances the signal] OUT (XLR balanced) ---cable------- ????? IN [G30 transmitter] OUT (signal transmitted wirelessly) IN [G30 receiver] OUT (1/4 unbalanced jack) --cable----- (1/4 unbalanced jack) IN [bEHRINGER Eurolive B615D Active speaker] as you can see, my problem is that I cannot feed the XLR balanced signal to the G30 transmitter in order to complete my setup. Do you have any ideas? Am I too optimistic about this proposed setup? Do you happen to know other products of line 6 with similar sound specifications to G30 that could help me? many thanks in advance George Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 19, 2013 Share Posted May 19, 2013 Why not just run from the mixer to the transmitter omitting the DI? Quote Link to comment Share on other sites More sharing options...
sgouros Posted May 20, 2013 Author Share Posted May 20, 2013 Thanks for the reply Could I do this? Is line signal the same as guitar signal? what if instead of a mixer, I have a line signal from let's say the left channel of my laptop? can I plug it directly to the transmitter?? Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 20, 2013 Share Posted May 20, 2013 All Line 6 wireless systems are unity gain so the output voltage is the same as the voltage of whatever you stick in the input. As long as you don't exceed the input limit of 6v p-p you will not need to make any special arrangements. Line level from XLR jacks can exceed this (depending on where you set your controls). Outputs from 1/4" unbalanced jacks, RCA's or 1/8" jacks is usually low enough to not exceed the limit. I would also expect output directly from a laptop to be acceptable. But you will need to check the specs for your mixer/laptop and make certain. The inputs to all Line 6 wireless systems is unbalanced and when using 1/4" plugs you MUST use unbalanced TS style (mono) plugs as the ring connection is for "bias" voltage to power microphones. Quote Link to comment Share on other sites More sharing options...
lilyren Posted December 26, 2013 Share Posted December 26, 2013 A useful post.I just want to see if someone can post something about the phone signal jammer.I'm wrting some articles about that and i have a little konwledge about that. Quote Link to comment Share on other sites More sharing options...
dboomer Posted December 26, 2013 Share Posted December 26, 2013 They are illegal in the USA. I've tested a couple and like cell phones they don't really bother Line 6 wireless unless they are very close to the receiver (like a couple of feet) Quote Link to comment Share on other sites More sharing options...
