Display of DSP Percentage? Newbie Question
sami568
Is there a way on the Stomp to display percentage of DSP used by the current preset?  If not, is there a chart published somewhere that indicates how much DSP the various blocks use up?  (So you can figure out how close to maxing out you are)    I guess if there are no elegant ways to determine CPU percentage, I could always try adding on a chorus to my signal path - if it accepts the extra block I am well within limits - if not, then I could try to add some less CPU intensive block and see what happens.
Here is the minimum I need:  ROTARY + PREAMP + DELAY + REVERB  (with expression pedal for PREAMP VOLUME and expression pedal for ROTARY MIX)   Is this too much CPU for the stomp????  (I guess I could live without the second expression pedal if necessary...)
ALSO - Let's say you have a preset that uses 99% of your DSP.  You are playing along and you dig into a note - or maybe you wiggle your expression pedal quickly - is it possible that you might exceed your CPU limit and cause some kind of signal interruption?    If so, what happens in such situations?   Do you just loose reverb or something - or does the sound drop out?
Thanks again for the help!  I am looking forward to getting my HX Stomp via Amazon TOMORROW!
Unfortunately, there's not an official one, but the link below SEEMS to be pretty accurate. I have no idea how it was calculated.
http://benvesco.com/store/helix-dsp-allocations/
Ultimately though, as a Stomp user I've never needed to get THAT detailed.  You kind of get a feel for it very quickly, and at least for me, when I do run out of DSP I can quickly search for substitute effect choices that get me there.
Quote
Hmmmm . . . this really doesn't sound like much DSP at all. First, the expression pedal won't take up DSP. That's a controller function, so you just connect the two pedals, and in the above, you're only using four blocks.
Quote
No, it's impossible for that to happen. If the Stomp says you can do the chain - you can do it.  There's no risk while playing that you suddenly won't have enough processing power.
Quote
"Unfortunately, there's not an official one, but the link below SEEMS to be pretty accurate. I have no idea how it was calculated.
http://benvesco.com/store/helix-dsp-allocations/"
Since I use a tube power amp (BOOGIE 250) I only use the preamp models.  There is no listing for those separately - but I bet I end up saving another 10% by this measure....  It is nice that the Stomp allows us to make this savings.  When I record I will use the full amp-cab models, but then I will be adding reverb and delay in my DAW - so I anticipate I will still be OK then too!
The table IS very also interesting as I get to see what all the model abbreviations stand for!  I cant wait to try the Bogner
