markkittus Posted January 17, 2014 Share Posted January 17, 2014 Hi! I want to use Pod Hd Pro to record my guitars through s/pdif. So, i connected the out from the Pod to the in of my Saffire Pro 14, then set the clock sync to SPDIF. If I don't do this, I have clicks every second. If I select SPDIF clock, the pod runs more stable, BUT when recording to logic some clicks appear. IS THIS FIXABLE? I mean, how can I set the clock master to the SDIF of Focusrite on Logic, instead of the Internal clock? Thanks! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 17, 2014 Share Posted January 17, 2014 go into the pod menus and change the sample rate on the spdif. most likely one of those settings will clear up the issue. Hi! I want to use Pod Hd Pro to record my guitars through s/pdif. So, i connected the out from the Pod to the in of my Saffire Pro 14, then set the clock sync to SPDIF. If I don't do this, I have clicks every second. If I select SPDIF clock, the pod runs more stable, BUT when recording to logic some clicks appear. IS THIS FIXABLE? I mean, how can I set the clock master to the SDIF of Focusrite on Logic, instead of the Internal clock? Thanks! Quote Link to comment Share on other sites More sharing options...
NucleusX Posted January 18, 2014 Share Posted January 18, 2014 +1 on the sampling rates. I would also look into your ASIO driver's buffer settings aswell as they can cause clicks too if not set properly. Both these settings need balancing out till you find an optimum. Quote Link to comment Share on other sites More sharing options...
markkittus Posted January 27, 2014 Author Share Posted January 27, 2014 Okay, i've tried sample rate to 44k on Saffire driver, pod spdif out and logic. Clicks. Tried to change everything to 48k. Clicks. Tried to put the clock on Spdif/Internal on both sample rates. Clicks. But, what is really strange, is that the clicks only appear when monitoring or recording to any DAW. When streaming spdif through my saffire directly it just works. Help :( Quote Link to comment Share on other sites More sharing options...
GlennDeLaune Posted January 27, 2014 Share Posted January 27, 2014 Try setting your I/O Buffer rate lower in Logic. Depending on how powerful your computer is and how much RAM you have, Higher Buffer rates can cause those click & pops you are talking about. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted January 27, 2014 Share Posted January 27, 2014 If you're connecting it to a mac, make sure to toggle the settings on the mac as well... from 44.1 to 48, or vice versus.... this has cleared quite a few issues...somehow toggling that resets some internal configs... can't guarantee it will fix... but its worth trying (assuming you are using a mac) Quote Link to comment Share on other sites More sharing options...
