Desire
Powercab USB´s capabilities
I am thinking of buying a powercab 112 plus.
I do not want to use it in FRFR mode, but rather take advantage of the simulation of the different speakers. Is it possible to record by connecting the powercab to a DAW (via USB)? If so, is it possible to choose the micro and distance simulation of this? (using speaker simulation ONLY), or do I have to use a real micro in front of the power cab and record like a normal amp?
Thank you for your help
It won't work via USB, but you can run direct (XLR) from the PC+ and select which mic model and mic distance you want.  Check out the PC+ manual page 13.
