funkninja Posted October 1, 2019 Share Posted October 1, 2019 Hey guys and girls, Apologies if this has been covered elsewhere. Is the Firehawk FX power supply ok to also power an Xotic SL Drive pedal at the same time (the polarity is the same, hot sleeve)? It would be helpful to not have to set up another ps onstage. Many thanks S Quote Link to comment Share on other sites More sharing options...
peanutismint Posted June 14, 2020 Share Posted June 14, 2020 Hi I just wanted to chime in to say I'm on a quest to power multiple pedals from the Firehawk too. This is what I've found: After buying a barrel plug adapter (2.1mm to 2.5mm because for some reason the Firehawk DC jack pin is a bit fatter than other pedals....) I split my Firehawk's PSU with a daisy-chain cable, but when I add even one small, low-draw pedal into the chain, I get horrible hum/digital whine. I've tried two separate daisy chain cables and different 9V power supplies and all I can figure is that maybe the Firehawk does actually draw the full 3000mA that its power supply apparently gives out and so adding more pedals/daisy chain cable is drawing too much current?? Did you have any luck with yours? Quote Link to comment Share on other sites More sharing options...
funkninja Posted June 15, 2020 Author Share Posted June 15, 2020 Hey @peanutismint, I was advised by Line 6 support not to use the PSU to power other pedals so I haven't tried it. It's possible the Firehawk PSU is not regulated which is why you're getting hum? Hope that helps :-) Quote Link to comment Share on other sites More sharing options...
