siafou Posted October 6, 2019 Share Posted October 6, 2019 Hi everybody, I was about to write a post about my problem but found the solution and wanted to share it since I didnt find an answer on the forum. (HX stomp USB plugged-in) Guitar-->HX-->Computer Basicly I only wanted to hear the output of my DAW. I wanted to have the wet signal from the hx stomp to my DAW and to have my DAW output to my headphones without having to hear the hx stomp monitoring and the DAW monitoring at the same time. Coming from the manual: When a DAW track's software monitoring is active, you'll likely not want to simultaneously hear the HX Stomp hardware monitoring signal. To achieve this, it is best to use the HX Stomp USB 5/6 inputs as your DAW audio track’s input source, and to select the Main L/R Output block on HX Stomp and turn its Level all the way down. I tried this way but the signal going to the DAW is dry with the 5/6 input. The way I found is: To set the DAW to use the input1/2 and to use output 3/4. Then I plug my headphones in the "send stereo" output Hope it helps somebody Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted October 9, 2019 Share Posted October 9, 2019 Weird ... the manual method worked just fine for me. Still, glad you found a way. Quote Link to comment Share on other sites More sharing options...
