Lupenhagen Posted October 12, 2019 Share Posted October 12, 2019 I wanted the new update, as i was running 2.71. Went through the steps, everything was going fine, it got stuck half way and didn't budge, i even left it going overnight. The mistake i made was closing helix updater, and restarting helix. Now it's stuck on the boot failure update screen, and helix updater can't even detect it. I searched through as much as i could find, tried the reset buttons and what not, nothing i do seems to work. I need help. Quote Link to comment Share on other sites More sharing options...
Peter Posted October 12, 2019 Share Posted October 12, 2019 1 hour ago, Lupenhagen said: I wanted the new update, as i was running 2.71. Went through the steps, everything was going fine, it got stuck half way and didn't budge, i even left it going overnight. The mistake i made was closing helix updater, and restarting helix. Now it's stuck on the boot failure update screen, and helix updater can't even detect it. I searched through as much as i could find, tried the reset buttons and what not, nothing i do seems to work. I need help. Turn off the Helix and close all line6/audio software. Reinstall HX Edit (2.82) - When you get to the options section of the install, leave them all checked. Start the Helix with FS6 and FS12 pressed (update mode) Start the LINE 6 Updater. (...don't use a USB-HUB, try annother USB-port if it still does not work use annother computer for the update) 1 Quote Link to comment Share on other sites More sharing options...
Lupenhagen Posted October 12, 2019 Author Share Posted October 12, 2019 9 minutes ago, Peter said: Turn off the Helix and close all line6/audio software. Reinstall HX Edit (2.82) - When you get to the options section of the install, leave them all checked. Start the Helix with FS6 and FS12 pressed (update mode) Start the LINE 6 Updater. (...don't use a USB-HUB, try annother USB-port if it still does not work use annother computer for the update) That worked! You're amazing! 1 Quote Link to comment Share on other sites More sharing options...
