pejkkj Posted November 10, 2019 Share Posted November 10, 2019 On HX Stomp I am trying to control the amp channel volume with an expression pedal so I don't have to use a volume block. I'm using a Dunlop mini volume pedal. When I select the amp channel parameter and try to learn the pedal, it gives me 0 in heal down, rises to 10 about mid way, and then goes back to 0 at toe down. How do I get it to go from 0 at heal down to 10 at toe down? I'm plugged into the AUX port on the Dunlop with just a standard TS patch cable. Quote Link to comment Share on other sites More sharing options...
pejkkj Posted November 10, 2019 Author Share Posted November 10, 2019 Got it fixed. Changed the dip switch inside for tip, then had to set the minimum to 10 and maximum to 0. Now it works with heal at 0 and toe at 10. Weird. 1 Quote Link to comment Share on other sites More sharing options...
