Can you give a Line 6 M9 global tap tempo using a separate tap tempo pedal?
Duckbreeze
I'm considering buying an M9 to run multiple time-based and modulation effects at once. In reading up on the pedal, it seems like it does not have global tap tempo, which really hurts how useful it is in a live setting. Will using a dedicated pedal like the MXR M199, Mosky Audio Tap Tempo Switch, or Ernie Ball Tap Tempo fix this issue?  If so, how would you use it?  Can it run into the expression jack or do you have to do something else?
Thanks!
  • 3 months later...
  • 2 weeks later...
