carlcaulkett Posted January 14, 2020 Share Posted January 14, 2020 macOS 10.14.6 Bitwig Studio 3.1.2 Line 6 Pod Farm 2.5 I've recently switched to using Bitwig 3.1.2 as my main DAW. I've just tried to load the Pod Farm VST but all I can see is a blank white rectangle where the plugin should be. I've just tried it in Ableton Live using Audio Units and the plugin loads fine there. Bitwig, however, does not support AU plugins, although it does support 32 bit VSTs, which is just as well because the Pod Farm VSTs appear to be 32 bit. I just cannot use them. Has anyone else succeeded in making Pod Farm work with the stated combination of software? Quote Link to comment Share on other sites More sharing options...
carlcaulkett Posted January 15, 2020 Author Share Posted January 15, 2020 I've contacted Bitwig about this. They say "the plugin is unfortunately around 10 years old and it seems that it uses an old OSX gfx library that is not supported anymore." Over to you! I purchased the software within the last 2 years and would have expected a slightly longer shelf-life, if I'm completely honest! Quote Link to comment Share on other sites More sharing options...
stevespod Posted May 13, 2020 Share Posted May 13, 2020 I've just been trying Pod Farm 2 in a few combinations with different DAWs. I've gone back to using the standalone version with Bitwig 3. Works really well. The AU version works well in Roland Zenbeats, but you can't get any midi control. Quote Link to comment Share on other sites More sharing options...
