st0rmchaser
Relay G10 with Spider V 120
I have the Spider V 120 amp and was given a Relay G10 for Christmas. Does the G10 talk directly to the Spider V amp, or is there a missing component that I need to purchase?
Thanks in advance.
I have just the G10T , the wireless transmitter, which I understand is one part of the Relay G10 system you're asking about. I plug the G10T directly into my Spider V 120 W amp's 1/4" input jack on the amp's front panel to charge, and then I use with different instruments  Works great! I don't have a separate charger as I'm guessing you do. So, my take is you should be good to go. (The amp must be turned on to charge the G10T.)  Good luck!
