gregkeene Posted February 16, 2020 Share Posted February 16, 2020 Is anyone else experiencing this? MacBook Pro 10.15.3 Helix Rack 2.82 HX Edit 2.82 COMMAND key is sometimes ignored when saving a preset and that seems to change a snapshot bypass setting on a parameter. An example where I can reproduce it: 1. In a preset with active snapshots, put a Gain Volume block (mine is stereo). 2. Use the pull-down to assign the Gain parameter control to snapshots. The bracketed value appears. 3. Change the value for that snapshot (e.g. [3.0 db]) 4. COMMAND-S to save the preset (meaning hold COMMAND and press S). 5. Sometimes it will save and sometimes it will turn off the snapshot control (as if COMMAND wasn't held since S is a shortcut to turn that off). It's not consistent. It could be many things, like it's busy talking to the Helix or buys saving and ignores the COMMAND key. But, I think know what it is, if the preset doesn't need saving (e.g. Save Preset under the file menu is grey). Hitting COMMAND-S will ignore the command and just do the S. Try COMMAND-S multiple times and it should save (if the it needs saving) and sometimes switch modes (when it doesn't and Save Preset is grey). Anyone else? Greg Quote Link to comment Share on other sites More sharing options...
