KennyKK Posted February 22, 2020 Share Posted February 22, 2020 Good day after trying to update m firmware and was requested to restart my unit it came up with Invalid error code 02. I literally tried all the suggested options and nothing worked we do not have any service providers near me and need this fixed asap? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted February 22, 2020 Share Posted February 22, 2020 PODxt Family Error Codes If you are experiencing the following error codes in the display of your PODxt device: Invalid Error Code 01 Invalid Error Code 02 Invalid Error Code 03 Invalid Error Code 04 Invalid Error Code 05 Invalid Error Code 06 please try the following: Try the Edit Buffer Initialization with the following steps: 1. Turn off the POD 2. Turn on the POD while holding down the Save and Edit buttons simultaneously 3. The POD's LCD screen should display Init Edit Buffer 4. Push the Output mode button 5. Turn the Select / Select Page knob one click to the right 6. Turn the Effect Tweak / Change Value knob to the left or right adjusting the contrast. If that does not help, please try re-installing the flash memory on the PODxt device using the instructions in the following link: Pod xt Series: Factory Reset, Reflash, and Firmware Updates If this does not solve the issue for you please locate your local Service Center for repair. Quote Link to comment Share on other sites More sharing options...
