rsvette12 Posted February 25, 2020 Share Posted February 25, 2020 Hi Guys: Helix LT is my unit Quick question on volume - noticing volume travel is very tricky meaning - not a lot of travel its either to soft or cranking Like a sensitivity issue of sorts not sure ? What block do you put the volume pedal on other than a volume block - do you use cab - amp - channel ? That said there no gradual travel in volume just push pedal and its way to loud - dont want to turn down volume knob on helix then backing tracks are to soft Any ideas would be great - thanks Quote Link to comment Share on other sites More sharing options...
rsvette12 Posted February 26, 2020 Author Share Posted February 26, 2020 Found this big difference - You have to set the volume pedal to "logarithmic" thanks to Jlondon for that Putting volume pedal on cab or channel or amp etc. without a volume block still stands what are you Guys doing thanks much Quote Link to comment Share on other sites More sharing options...
