brian6string Posted February 1, 2014 Share Posted February 1, 2014 I just uploaded my current suite of tones to CustomTone. You can find them at: http://line6.com/customtone/profile/brian6string They all: Are stereo Assign FS1 to turn amp 1 off/on (on by default) Assign FS2 to turn amp 2 off/on (on by default) Assign FS3 to turn on/off the Memoryman delay (off by default) Assign FS4 to turn on/off the comp/boost (off by default) Assign exp pedal 2 (I use an external) to control the amount of reverb Some of these mix dual amp models, some use dual paths to emulate dual mic'ing of a single amp. The dual amp models (AC30+Plexi, AC30+JCM800, AC30+Dual Rectifier, Dual Rectifier+Epic, JCM800+SLO) all add a tiny bit of 100% wet digital delay to the amp on the right side of the mix, in order to increase stereo separation...a really nice effect. The dual mic'd models (AC30, Dual Rectifier, Epic, Gibson, JCM800, Plexi, SLO) all mix both signals to the center. All models are set to be at around the same output level (aka unity), at least to my ears, with my setup (1998 PRS CE-24). I've spent a good deal of time tweaking the EQ settings to get them sounding pretty good (TME, WMS). If you're new or are looking to add some stuff to your collection, enjoy. The bolded ones above are my favorites if you're looking to just try out a couple. Brian 1 Quote Link to comment Share on other sites More sharing options...
