pfranklin1 Posted April 2, 2020 Share Posted April 2, 2020 I have tried guitar into pod, out L/mono #25 to front of amp & no sound. I tried guitar to front of amp & pod out of #25 to amp FX return & no sound. Also I have the #25 switched to amp. The only way I can hear it is thru headphones. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted April 3, 2020 Share Posted April 3, 2020 For starters, what is a #25 ? Is that the 1/4 inch output ? I assume the guitar amp works fine without the pod and has sound ? Quote Link to comment Share on other sites More sharing options...
pfranklin1 Posted April 6, 2020 Author Share Posted April 6, 2020 Hey Joel_brown, yes the #25 is the L/mono output. The amp is fine. I also went into inputs to guitar & same. Outputs to stack or combo. Any help would be great. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted April 7, 2020 Share Posted April 7, 2020 Try another amp or plug it into a PA mixer. If it still doesn't work then it sounds like you need to send it to a Line6 authorized repair center. Make sure your volume on the POD is turned up all the way. Sometimes it's the simple things that get us. Quote Link to comment Share on other sites More sharing options...
pfranklin1 Posted April 9, 2020 Author Share Posted April 9, 2020 joel_brown, thanks for the input. I called tech support & felt like an idiot. I had no idea you had to have the volume at least half way up. Everything is great now. Thanks again. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted April 10, 2020 Share Posted April 10, 2020 You're not the first person that's done this. That's why I mentioned it. Quote Link to comment Share on other sites More sharing options...
