pod 500-500x Inglés problema con el volumen del amp cuando seleccion el limpio y la distorcion? problem with amp volume when selecting clean and distortion
jorgecasas33
Could someone help me with this question, how can I assign the distortion of an amplifier to a button without lowering the entire volume of the amplifier when I press it? my problem is that I want to be able to listen to the head with distortion and without distortion but when I do it the volume is lowered too much .... :(
Given for granted that it's absolutely normal that an amp with a certain volume output number/value is perceived much louder when distored than when it is clean..
the simpler solution to get what you need would be to do 2 patches with the same amp, each one with its different DRIVE setting,
set the volume of the CLEAN patch to be fairly high to get the best signal/noise ratio,
then compare the distorted patch to the clean one and set its volume to get the same perceived volume (surely its volume number will need to be set to a lower value than in the clean patch).
If the small lag time which occours when swithing patches is a problem, alternatively and by using just one patch you could assign both the amp DRIVE and VOLUME parameters to the Expression Pedal and set the min a max values of the parameters to work in the opposite direction of each other, ie when (by using the pedal) the amp DRIVE increases the VOLUME decreases at the same time to compensate for the perceived different volume which would occour not doing so, and viceversa.
another solution could be to build a patch with 2 same amps in the chain but with different DRIVE and VOLUME settings and assign both of them (when one is turned on and the other is turned off) to the same footswitch, so you can switch between them 2 easily (and without lag time), but this solution is DSP hungry and you wouldn't be left with much resources to add many other blocks in the chain.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Thank you very much for your answer, late to answer because I wanted to try it first, and the option to add volumes through the expression pedal was better for me ... I did not know that you could do that.
Normally I try to accommodate the guitar patches to have the minimum possible, in this case if I have to do a different one since my idea was to have two amplifiers (clean / Dist) and wha pedal and a microphone with effects.
thank you very much anyway your information was very useful to me
