Helix Rack AND Floor??
journeyman73
You could use the Floor as a MIDI controller for the Rack, but it would not give you nearly the same functionality as the Helix Control with the Rack. It would also be a relatively painful and tedious process programming the Floor to control the Rack, depending on how detailed of control you want. With the Control, everything is much more automatic.
One way to think about is that the Helix Rack and Control are designed to give you the same sort of hardware control as the Floor (minus the on-board pedal, of course), but just broken out into two physical pieces. The Control is an extension of the Rack in that sense.
Thanks Phil - I realize its a trivial matter but if the Control had the built in expression, so that everything was just neat and tidy I would probably forego the floor (recognizing the main drawback of that point would be needing to go over to where the Rack was to do any heavy editing requiring the screen)...
i like the idea of having the ‘brain’ up off the floor, so maybe i will just have to suck up a separate exp pedal...
