sglovjoh Posted April 21, 2020 Share Posted April 21, 2020 Can I do everything the Shuriken and POD HD500X is capable doing as with the Helix? For Instance can I start off in a clean amp tone in Drop D tuning and go into a high gain amp tone into an open G tuning with one step of a foot switch like can be done with the Helix? Quote Link to comment Share on other sites More sharing options...
Stephanie29 Posted July 10, 2023 Share Posted July 10, 2023 Hello, i have some change this you can read this The Shuriken and POD HD500X are both multi-effects processors that offer a range of amp models, effects, and signal routing options. While they provide a variety of tones and capabilities, they may not offer the same level of flexibility and seamless switching as the Helix, which is a more advanced and feature-rich model. PayMyDoctor Login The Helix is known for its extensive amp and effect modeling capabilities, as well as its ability to switch between different presets, amp tones, and tunings with a single footswitch press. It has a more sophisticated routing system and a larger selection of amp models and effects compared to the Shuriken and POD HD500X. While the Shuriken and POD HD500X can provide a range of tones and allow you to switch between different amp models and effects, their switching capabilities may not be as seamless or comprehensive as the Helix. You may need to manually adjust settings or switch patches to achieve different amp tones and tunings. thamks for read i hope my ans. is useful. Best regard Quote Link to comment Share on other sites More sharing options...
