POD XT Screen B/W
I have pulled out my POD XT after a nearly a decade. I no longer have the original AC power supply, but found another one that plugs in. However, the screen only comes on in Black & White - not the yellow.
I've updated all the drivers with Monkey and my computer recognizes the device as the soundboard. But when I plug in headphones or route it to the amp, I get no sound.
Could this be because it's not using the OG power supply? Before I go out and spend $50 on a new one i'd like to see if it could be something else.
Are the specs of the AC power supply EXACTLY what is required for the POD? If not, you run the risk of damaging the unit. The POD power supply is an AC transformer, not DC like a lot of power supplies. If your power supply's output is 9v DC, don't use it.
According to the manual,
"PODXT: Connect only to AC power outlets rated 100-120V or 230V 47-63Hz (depending on the voltage range of the included power supply)."
