sandman27959 Posted February 7, 2014 Share Posted February 7, 2014 Hi all, Can someone please confirm for me that the little L6 FBV 2-button footswitch will allow you to switch between A,B,C, and D on the Amplifi? I know it's an FBV switch, but I never see it mentioned in any of the compatibility specs. Maybe it's just an attempt to market the more expensive FBV's, but I just need to be able to use the 4 presets on the Amplifi. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
sandman27959 Posted February 11, 2014 Author Share Posted February 11, 2014 I thought I'd answer my own question and give it a try. Short answer... No. The 2-button FBV footswitch does not work with Amplifi. It's not compatible. I received mine today and it doesn't switch channels reliably, so it'll be going back to Amazon. Disappointing. It looks like there's no simple solution to switching channels remotely without spending a hundred bucks for features I don't need. Quote Link to comment Share on other sites More sharing options...
cgabell Posted June 15, 2015 Share Posted June 15, 2015 I tried the FBV2 switch with my Amplifi 150 and also had unreliable results, it sometimes switched first time to one of the other tone channels, but took upto 11 presses other times. Shame. Quote Link to comment Share on other sites More sharing options...
richardroi Posted June 22, 2015 Share Posted June 22, 2015 hey I have FBV SHORTBOARD MKII, results are unreliable also. Line6 Confirmed that delay on changing presets cannot be changed! They should recall AMPLIFI! jpullen Jun 18, 09:55 AM Richard, Thanks for your ticket inquiry and comments. After testing the unit here in the support office, we found this is an aspect of the unit's processing speed, and cannot be changed. We apologize if you're having issues with live situations, and will let you know if any solutions are reached in the future. We appreciate your business and hope you'll continue to enjoy Line 6 products. Kind regards, Jason-Line 6 support Quote Link to comment Share on other sites More sharing options...
