Hd 500 With Mxr Pedal Chorus
srv900
why do you use an additional chorus, when you use the hd?
This means more cables, additional power supply, more noise in signal path, because the hd had to switch d/a, a/d!
The hd 500 provides anything you need.
Just my 2 cents.
I can understand this, to be frank I think that both the Flanger and Chorus FX on the HD500 are lacking to be honest.
I own a MXR chorus - which is great - but do I hook it up to the POD? - Well no because when I gig with the POD I want a quick set up and tear down and so work the best I can with the inferior modulation FX available on the POD. I have said this many times but I honestly don't think the punters can tell the difference as long as your sound is close to decent.
