MattK1986
Spider V 30 MK II
Hey guys,
So I have the amp above in the subject header, just wanted an easy walkthrough of how I can record some stuff to computer, presumably via USB.
I have the app installed on my iPhone and I’m trying out various tones on the cloud, now looking to put some of my own stuff into the mix.
Any help is greatly appreciated.
Thanks.
Spider V comes bundled with Cubase LE recording software. Just register your amp in your Line 6 account and you will be sent a link to download Cubase LE. To record with Spider V; connect the amp to your computer via USB, make sure the selector switch on the back of the amp is set to the correct USB port. If you are using a PC you will need to download the correct drivers from line6.com/software. Once your Spider V is connected to your computer, open your recording software and select Spider V as your input and output in the audio settings.
