hsi0409 Posted July 25, 2020 Share Posted July 25, 2020 Hi I tried to update flash memory using Line 6 Monkey and an error popped up. So I disconnected the USB cable and power of HD300. and when I turned on the HD300, the screen remains blank. How can I fix this? I tried to do Factory Reset by pushing A button while put the power on. Nothing happens. Now when I connect the usb cable between the unit and computer, The Line 6 Monkey detects the HD300 but I cannot perform Flash Memory update. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted July 25, 2020 Share Posted July 25, 2020 AFAIK unfortunately the POD HD300/400 don't have a safe mode (eg like the HD500) which can be specifically used to flash the firmware when the device is basically bricked, but only the Factory Reset mode (hold A while powering on) and Test mode (hold Tap while powering on). However you might want to try some of the proposed solutions I've read on a post on facebook written in thai language: How to Fix for Update Firmware Failure for POD HD300/400 By PHOLROCK I guess you'll need to use google translate, unless you are thai. I can't help more given that I use an HD500. Good luck. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
nickkucel Posted July 27, 2020 Share Posted July 27, 2020 I had the same problem. The update process would give me an error message. So I read the page the guy had written in Thai. The solution is to use a different (newer) computer and a different USB cable. Quote Link to comment Share on other sites More sharing options...
hsi0409 Posted July 30, 2020 Author Share Posted July 30, 2020 I called a distributor(in Korea), he said it might be mainboard problem, if it is, it will cost so much (like 200 dollars) . I gave up.. cannot use this HD300 anymore.. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted July 30, 2020 Share Posted July 30, 2020 10 hours ago, hsi0409 said: I called a distributor(in Korea), he said it might be mainboard problem, if it is, it will cost so much (like 200 dollars) . I gave up.. cannot use this HD300 anymore.. I doubt very much that a firmware flashing procedure could physically damage a mainboard in any way. Unfortunately I don't know of any other ways to properly install the firmware on that device, but for me the problem is just that, and a Line6 technician would know how. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
Groot1 Posted April 19, 2023 Share Posted April 19, 2023 I was able to install a firmware on the tas1020b component and it recognizes it as an audio device. Having the correct firmware I think you can fix it because the one available for download is too big and doesn't fit on the component. PS: I bought it already with a firmware problem I thought it was just an update but I lost money and I'm just curious so I might be completely mistaken Quote Link to comment Share on other sites More sharing options...
