ncockerill
Stagesource L3S -- Use with 2 other Subs?
Got an outdoor gig next weekend and need some advice.  I have 2 Stagesource L3t, 2 Stagesource L2t and a single Stagesource L3s sub -- which are great and all I have needed for most indoor gigs.  But since this a large outdoor space, I wanted to increase my low end by using another sub or two.  My singer has a pair of JBL EON 518s subs and I was thinking of using those.
Would the following setup work?  Can I use the XLR outputs AND L6 link simultaneously?  Thoughts?
*TO MY KNOWLEDGE*
Yes, it will work
The analogue outputs on the back of the L3s are straight forward pass-thru's so whatever is on the analogue inputs is on the analogue outputs.
The L6Link should send on a digitised L/R signal
But, if it were me, I think I'd be more likely to run into the JBL's first and then passthru them into the L3s and onward with the L6Link
SiWatts69 --- thanks for the reply.  Much appreciated.  So you would be more likely to do run to the JBLs first, like the updated diagram below?  What would be the advantage or reasoning? Thanks again!
No particular reason and certainly not one with a technical basis.
The only technical advantage I can see is that by going into the JBL's first you leave yourself the option of running passthru to the remaining Line6 tops in analogue from the L3s *if* the l6link doesn't play ball.
