davidlehew 0 Posted August 26, 2020 Hey all. I was wondering why the minimum frequency for a hi cut block is 1000 hz? I'd love to have access to a lower frequency so I can do some fun filter sweeps with an expression pedal or even with the knobs. Is this going to be in the new update? Is there a work around to achieve this goal? Quote Share this post Link to post Share on other sites
lou-kash 42 Posted August 26, 2020 2 hours ago, davidlehew said: why the minimum frequency for a hi cut block is 1000 hz? Likely because a signal below 1 kHz doesn't count as "high" anymore. :) 2 hours ago, davidlehew said: Is there a work around to achieve this goal? A wah-wah? Quote Share this post Link to post Share on other sites
davidlehew 0 Posted August 27, 2020 I may be wrong, but I think the wah wah is a movable bandpass filter. That's not what I'm trying to do 32 minutes ago, lou-kash said: Likely because a signal below 1 kHz doesn't count as "high" anymore. :) A wah-wah? . Correct, below is 1000 hz is probably more mids territory. However what I want is to be able to cut everything above a very low frequency and slowly sweep up to create dramatic sound. Quote Share this post Link to post Share on other sites
lou-kash 42 Posted August 27, 2020 Use two Lo/Hi Cut blocks to double the effect. Or use the Parametric EQ and also add the High/Mid Gain/Freq parameters to your expression pedal. Sounds spooky indeed! :) Quote Share this post Link to post Share on other sites
lou-kash 42 Posted August 27, 2020 At the same time you can also reverse the Low Gain to slightly boost the lows in heel position. Quote Share this post Link to post Share on other sites
lou-kash 42 Posted August 27, 2020 Heel: Toe: Quote Share this post Link to post Share on other sites
