Latam Posted September 13, 2020 Share Posted September 13, 2020 Hi, recetly I've switched from floor to HXFX because of its size. I knew the difference but there is one thing which surprises me. I use two separate paths, one to my clean and one to me overdriven amp. On helix, I split the signal at the start and choose 2 different output blocks (L and R) for each path. On HXFX, I must merge the signal in the mixer block and pan path A to left and path B to right. So far so good. But, on helix, when I disconnect one of the outputs (to play with just one amp at home), signal merged automatically to mono(left) output. On HXFX seams that signal is hard split between both outputs even when just one output is connected. Do you have any idea please how to solve the issue without changing the mixer block pan to centre every time I change my amps setup? Thank you in advance! Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted September 14, 2020 Share Posted September 14, 2020 18 hours ago, Latam said: on helix, when I disconnect one of the outputs (to play with just one amp at home), signal merged automatically to mono(left) output. Hmmm... I don't think that's actually how it works. Can you attach your preset here so we can take a look? I suspect you've actually got both of your L/R outputs carrying a mixed signal because it got merged back together somewhere else. Quote Link to comment Share on other sites More sharing options...
Latam Posted September 15, 2020 Author Share Posted September 15, 2020 Hi, thanks for reply. Maybe I named the topic wrong - it's more like dual mono path rather than stereo. This is tha way I set up my HXFX (or stomp). I split the signal and chose the path via snapshot. Then in the mixer, I split the paths between left and right. Thats the way I can A/B/Y my amps using left/right (main) 1/4 outs. But when I use just L main out (mono), signal paths doesn't merge and I hear just path A (or nothing when I switch to path B) On the Helix floor, I used to split the paths in the same way but I didn't merge them at the end. I chose 1/4 out for both paths and pan one to the left and the other one to the right (sorry, can't share a picture as I don't own floor any longer). And when I disonected right jack, both paths merged to left 1/4 out. I can't do that on hxfx or stomp because there is no other output block for path B apart from FX send. Quote Link to comment Share on other sites More sharing options...
bassbene Posted September 16, 2020 Share Posted September 16, 2020 Only option for an "internal" solution might be duplication of presets. One for your dual output setup, one for single output. As an "outboard" solution you could use a mini-mixer or similar device between the Helix and the amp to merge both signals. Quote Link to comment Share on other sites More sharing options...
Latam Posted September 22, 2020 Author Share Posted September 22, 2020 Hmm, thats not the answer I want to hear :-) I use HXFX to prevent from additional external solutions a doubling of presets is crazy when you want to adjust something. I just wonder why it behaves so different from helix. I would expect opposite as split in two paths with two output blocks seams "harder" than just mixer L/R split. I'll test the same on HX Stomp. Quote Link to comment Share on other sites More sharing options...
Latam Posted September 26, 2020 Author Share Posted September 26, 2020 Hi, I just solved the issue! Hxfx behaves just the same way the helix is - if the right output is not connected, signal merge to the left. The problem was probably in my presets. I imported them from helix and even everything was set properly, some settings from helix stay active but not visible in hx edit of hxfx. After I copy everything block by block to a new preset, problem disappeared. Quote Link to comment Share on other sites More sharing options...
