SmooBG Posted October 4, 2020 Share Posted October 4, 2020 Hi Friends, I just upgraded to a 27' iMac (Catalina OS). I have read all of the other suggestions to get this working, but none of them have worked. I can see the 'Line 6 Audio MIDI Devices' at the bottom of the window in the system preferences, but when I click it, a new window opens that says, "Line 6 Device: No devices connected.". I have also gone to 'Security & Privacy > Privacy' in the system preferences, but there are no Line 6 devices that show up there. Is Line 6 still working on a way for this to work on newer Macs/Catalina? Thanks, Brad Quote Link to comment Share on other sites More sharing options...
Kalzoo58 Posted October 5, 2020 Share Posted October 5, 2020 Just bought the POD HD Pro X rack mount and having the exact same problems. My MacBook is running Catalina 10.15.7. I saw the "Don't upgrade to Big Sur!!" announcement but I thought Catalina wouldn't be a problem. Not being able to use the POD PRO edit is a real pain, so would be grateful if anyone has a solution. Quote Link to comment Share on other sites More sharing options...
SmooBG Posted October 16, 2020 Author Share Posted October 16, 2020 SOLVED! Line6 Support worked with me for a while to figure this out. After performing a fresh install of 'Line 6 Audio-Midi Driver 7.6.8', and restarting my Mac (which is required), I immediately went to System Preferences > Security & Privacy > Click the lock to make changes. Click the 'Allow' button next to "Some system software was blocked from loading", and then select the Line 6 Audio-Midi Driver. You only have a few min. after restarting your system to do this before it goes away. This is a huge relief to have this fixed! I hope this helps someone else. 4 2 Quote Link to comment Share on other sites More sharing options...
Kalzoo58 Posted October 17, 2020 Share Posted October 17, 2020 Many thanks for this - it sorted the problem. Downloaded the driver and followed your procedures, plugged on the POD and it worked! The screen grab was also a great help. Again, many thanks for your efforts. 1 Quote Link to comment Share on other sites More sharing options...
SmooBG Posted October 18, 2020 Author Share Posted October 18, 2020 Kalzoo58 glad it worked for you! Rock on, bro! Quote Link to comment Share on other sites More sharing options...
Jose_El_Gallo Posted October 29, 2020 Share Posted October 29, 2020 On 4/10/2020 at 23:28, SmooBG said: Hola amigos, Acabo de actualizarme a un iMac de 27 '(Catalina OS). He leído todas las otras sugerencias para que esto funcione, pero ninguna ha funcionado. Puedo ver los 'Dispositivos de audio MIDI de Line 6' en la parte inferior de la ventana en las preferencias del sistema, pero cuando hago clic en él, se abre una nueva ventana que dice, "Dispositivo de Line 6: No hay dispositivos conectados". También he ido a 'Seguridad y privacidad> Privacidad' en las preferencias del sistema, pero no hay dispositivos de Line 6 que aparezcan allí. ¿Line 6 sigue trabajando para que esto funcione en Mac / Catalina más nuevas? Gracias, Puntilla HOLA! YO TENGO ESTE SISTEMA OPERATIVO; HAY Y NO PUEDO VER EL EDITOR DE LA POD HD500X; HAY ALGUNA SOLUCIÓN? GRACIAS! Quote Link to comment Share on other sites More sharing options...
felipegssantos Posted August 31, 2021 Share Posted August 31, 2021 Almost an year later, thank you for sharing this solution! I just bought a POD HD500 and ran into the same problem on Big Sur. Your solution worked beautifully. Quote Link to comment Share on other sites More sharing options...
SmooBG Posted August 31, 2021 Author Share Posted August 31, 2021 20 hours ago, felipegssantos said: Almost an year later, thank you for sharing this solution! I just bought a POD HD500 and ran into the same problem on Big Sur. Your solution worked beautifully. Glad it worked for you, felipegssantos! This is what this forum is all about! Quote Link to comment Share on other sites More sharing options...
offerni Posted February 28, 2022 Share Posted February 28, 2022 On 10/16/2020 at 11:29 AM, SmooBG said: SOLVED! Line6 Support worked with me for a while to figure this out. After performing a fresh install of 'Line 6 Audio-Midi Driver 7.6.8', and restarting my Mac (which is required), I immediately went to System Preferences > Security & Privacy > Click the lock to make changes. Click the 'Allow' button next to "Some system software was blocked from loading", and then select the Line 6 Audio-Midi Driver. You only have a few min. after restarting your system to do this before it goes away. This is a huge relief to have this fixed! I hope this helps someone else. Thanks, this worked for me using macOS 12 Monterey! Quote Link to comment Share on other sites More sharing options...
LBProduction Posted April 26, 2022 Share Posted April 26, 2022 I have done all this and it still doesn't register that it is connected. Not sure if I'm missing something or... Running Mac mini/ Monterrey/ POD HD500X Thanks for the help Quote Link to comment Share on other sites More sharing options...
Redfox7340 Posted August 25, 2023 Share Posted August 25, 2023 On 10/16/2020 at 12:29 PM, SmooBG said: SOLVED! Line6 Support worked with me for a while to figure this out. After performing a fresh install of 'Line 6 Audio-Midi Driver 7.6.8', and restarting my Mac (which is required), I immediately went to System Preferences > Security & Privacy > Click the lock to make changes. Click the 'Allow' button next to "Some system software was blocked from loading", and then select the Line 6 Audio-Midi Driver. You only have a few min. after restarting your system to do this before it goes away. This is a huge relief to have this fixed! I hope this helps someone else. On 2/27/2022 at 10:08 PM, offerni said: Thanks, this worked for me using macOS 12 Monterey! this also worked for Big Sur Quote Link to comment Share on other sites More sharing options...
kamildz Posted December 21, 2023 Share Posted December 21, 2023 Hi, I can't get this to work on Ventrua 13.5.1, there is no lock and the whole page looks different Quote Link to comment Share on other sites More sharing options...
drummerchuckb Posted March 8, 2024 Share Posted March 8, 2024 Same as kamildz....ventrua and all different. Why do they make this crap so hard?? Quote Link to comment Share on other sites More sharing options...
Slayer_6969 Posted March 11, 2024 Share Posted March 11, 2024 I have the same issue on Sonoma 14.0, I do find the window in the settings, however allowing the line6 drivers does not work and the Line 6 Midi Audio Devices Setting Extension does also not seem to work properly and looks like this: 2 Quote Link to comment Share on other sites More sharing options...
