POD 2.0 Input Clipping/Interference Problem
Help - My POD 2.0 has started to exhibit some kind of input clipping/interference. I’ve checked cables and surge protector and everything is normal there but intermittently the input sound will glitch. Dos this indicate that my device is dying? I’ve heard of capacitors going bad but has anyone experienced this and how did you resolve. Much appreciated. Might be time to pull the trigger on a POD Go.
You may want to try a few things:
  • Swap your cables and see if that helps. (I recommend not using homemade cables.)
  • Check your settings, especially the AIR switch.
  • Try moving all of the knobs and sliders.  Work them a little bit. Over time they can get oxidized and that can cause problems.
Good luck.
