POD GO Volume Knob does not work...
franzenmichel
  • 9 months later...
Have you upgraded to v1.30? How are you connecting Pod Go? if you are connecting to Amp Out, and not main out or headphones, prior to v1.30 the Volume knob doesn't work when you're connecting via the 'Amp out' socket.  In the latest v1.30 you now have volume control options (go into: Global Settings > Ins/Outs > Volume Knob)
Prior to 1.30, POD Go’s Volume Knob only controlled the Main Outs (and Phones out, of course). Now you can choose whether it controls the Main Outs, Amp Out, or both. IMPORTANT: When connecting POD Go's AMP OUT to the input of a guitar or bass amp, we strongly recommend leaving Global Settings > In/Outs > Volume Knob to "Main Outs," as turning the Volume knob with any other setting will be like adding many boost pedals or attenuators between POD Go and your amp; that is, it'll probably sound totally wrong. Only set this to "Amp Out" or "Both" when connecting the Amp Out to a full-range, flat response (FRFR) speaker, studio monitor, or similar playback system.
  • 1 year later...
  • 10 months later...
On 1/15/2023 at 6:56 AM, Joattraction said:
Where can I access the Global Settings?
Press the two page buttons simultaneously.
Then go to the "global settings" section by pressing the button on the right, under the screen.
In the second page of the "Ins/Outs" section you will find "Volume Knob". :)
