vjm69 Posted January 24, 2021 Share Posted January 24, 2021 Helix Native compatible with Cakewalk Bandlab daw? Quote Link to comment Share on other sites More sharing options...
Axemadman74 Posted January 24, 2021 Share Posted January 24, 2021 Yes. I use it all the time along with my Helix Floor. Cakewalk should detect it automatically and it will appear in your VST plugins once installed. \m/ Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 24, 2021 Share Posted January 24, 2021 23 hours ago, vjm69 said: Helix Native compatible with Cakewalk Bandlab daw? Well, as Cakewalk Bandlab utilises VST3 plug-ins- yes, Native is VST3. Quote Link to comment Share on other sites More sharing options...
gdx65 Posted October 19, 2022 Share Posted October 19, 2022 Hi, just installed Cakewalk, Helix Ntive appears in the Track and start the Helix. I see the guitar signal coming into Helix but no sound in my soundcard output. All is ok when i use other plugins in the same track... thanks for the answer. Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 19, 2022 Share Posted October 19, 2022 On 10/19/2022 at 9:38 AM, gdx65 said: Hi, just installed Cakewalk, Helix Ntive appears in the Track and start the Helix. I see the guitar signal coming into Helix but no sound in my soundcard output. All is ok when i use other plugins in the same track... thanks for the answer. Hi, You are not very clear in explaining how you are getting the guitar signal into Cakewalk, but you do mention a “soundcard” output. As you say that you have just installed the DAW, you may want to see this about setting up. It’s not Cakewalk, but most DAWs are similar. The Owner’s Manual for both Cakewalk and Native is alway a good place to start with this sort of stuff. https://line6.com/data/6/0a020a4179ea61fd2e9472da7/application/pdf/Helix Native 3.15 Pilot's Guide - English .pdf https://bandlab.github.io/cakewalk/docs/Cakewalk Reference Guide.pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
gdx65 Posted October 19, 2022 Share Posted October 19, 2022 On 10/19/2022 at 1:37 PM, datacommando said: Hi, Yes your are correct, I have been too short in the description. The guitar signal gets into Cakewalk via a PreSonus AudioBox iTwo sound card. All god all is wokring well with other plugins. When I start the Helix native i see the guitar signal getting into the Helix and out but no sound out from the Sound card (headsets/output to monitors). But now the problem is solved, the guitar cable was defective :-) anyway thanks for answering... You are not very clear in explaining how you are getting the guitar signal into Cakewalk, but you do mention a “soundcard” output. As you say that you have just installed the DAW, you may want to see this about setting up. It’s not Cakewalk, but most DAWs are similar. The Owner’s Manual for both Cakewalk and Native is alway a good place to start with this sort of stuff. https://line6.com/data/6/0a020a4179ea61fd2e9472da7/application/pdf/Helix Native 3.15 Pilot's Guide - English .pdf https://bandlab.github.io/cakewalk/docs/Cakewalk Reference Guide.pdf Hope this helps/makes sense. HI, thanks for the reply. I a 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 20, 2022 Share Posted October 20, 2022 On 10/19/2022 at 3:16 PM, gdx65 said: now the problem is solved, the guitar cable was defective :-) Hi, Good to know that you have solved the problem. With all this high tech software we tend to think that something is wrong with the installation, and later we find that the everyday cable is the fault. It's an easy fix. Have fun recording. Quote Link to comment Share on other sites More sharing options...
HelixUser333 Posted June 11, 2024 Share Posted June 11, 2024 I have, since update 3.71, a problem with the vst3 plugin with cakewalk. When i add a helix native effect to a channel, the channel volume jumps to max immediately. If i deactivate the effect, it is gone again. It is so with every new effect I add, no matter which preset. Cakewalk version is 29.9.098. If i have a channel with a plugin effect active, it will work somehow. If i change something, however, it will do the mentioned above. Quote Link to comment Share on other sites More sharing options...
