gotto Posted January 30, 2021 Share Posted January 30, 2021 I am seeking advice using my unpowered Kemper with my Line 6 stage setup. I have a StageScape Mixer and StageSource speakers and monitors, l3t and l2t respectively. Hooking up through recommended outputs of Kemper into the Stagescape inputs sounds terrible. Is it best to bypass direct to the powered speakers?The Stagescape does have a modeler icon. Greg Quote Link to comment Share on other sites More sharing options...
flanger68 Posted February 2, 2021 Share Posted February 2, 2021 First thing i would check is the output level of the Kemper: are you sending a signal that's way too high into the M20d ? You should send a signal with an average level around -18 dB, and with peaks at -12 dB ....did you do the auto-trim procedure on the M20d channel where you have the Kemper hooked in ? Else, the channer on the mixer may be malfunctioning, try another channel ? Quote Link to comment Share on other sites More sharing options...
gotto Posted February 7, 2021 Author Share Posted February 7, 2021 Thx, I will review output and auto trim. Quote Link to comment Share on other sites More sharing options...
