monnkey2 Posted March 1, 2021 Share Posted March 1, 2021 Since the Boss Tube Amp Expander has a built in effects loop, can you use it to do 4CM with a tube amp? What I’m most curious about is being able to switch between my tube amp and the modeled amps in the Helix. Has anyone tried this? Will it work since it would be cutting the power amp inside my tube amp out of the equation when using the Helix models (because the fx loop in the TAE comes after my amp)? Is this safe for my tube amp, and will it work? Quote Link to comment Share on other sites More sharing options...
