gmkl Posted March 6, 2021 Share Posted March 6, 2021 Hello Just got the POD GO a week ago and I am having 2 issues with it. The main one is complete Volume Loss. Strange thing is that is only happens when I go to a preset with the Tron Up in it. Not every time, but almost every time. If I take the Tron Up out of the Preset, it doesn't seem to do it............Volume stays on like normal. I use the HX Stomp for some bigger Gigs and this is for another type ofGig. Because of that, I like the sounds and it is very familiar and easy to work with, so I want to keep it. But not if it's going to keep cutting out. I can live without the Tron sound, but still seems peculiar. I have another week with it before I can return it as defective. Anyone heard of this or have any thoughts, ideas or suggestions ?? The 2nd issue ........and it only came up today. While I was re-assigning the foot switches in Stomp Mode............the unit froze.......2x in like 5 minutes. I couldn't get it to do that again after that. Any help would be much appreciated. Thanks for everyones time ! GMK Quote Link to comment Share on other sites More sharing options...
voxman55 Posted March 7, 2021 Share Posted March 7, 2021 Have you upgraded to the latest v1.12 firmware? If not, I strongly recommend you do so becauwe v1.12 should fix the freezing issue. If you have, you might have a filepath glitch so reset your PG back to factory using C and D buttons. If you are still having problems after the above, log a ticket with Line 6 customer support. Quote Link to comment Share on other sites More sharing options...
