Pod Go headphone volume very low
Kenny202
Need to use my pod go at home sometimes headphones only for reference setting up patches etc. I have the big volume knob turned all the way up and it is ok, just but would definitely like a little more volume. I got a good set of Audio Technicas and I am sure they are not the problem. Is this a common complaint or am I missing something? Is there a solution or adjustment somewhere? I googled it but can only find people having issues with an imbalance of higher output to their DAW than the headphones.
By the way I am using headphones with a 1/8" jack so need to use a 1/8 to 1/4" adapter. Should the adapter be 1/8" to 1/4" stereo or mono or otherwise?
I am loathe to add extra gear like headphone amps etc, more cables, power supplies. is there anything I can do?
I have Audio Technica ATH m50x headphones and with the PG volume knob at between 12 and 3 o'clock, the volume is plenty loud.
Some amp models, e.g. the new Princeton, are noticeably quieter than others especially set clean. Make sure you have your PG set to Line out.
