jooban Posted August 15, 2021 Share Posted August 15, 2021 I have been using plugins almost exclusively now, and it's been annoying me having to manually switch presets. So I asked around and I was told I could use a pod hd500x to switch between presets on my plugins. So I bought one used and for the life of me I cannot figure out how to do it. I'm hoping, that someone here can help me out? the plugins I use are neural dsp plugins, if that's needed info Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted August 15, 2021 Share Posted August 15, 2021 You can’t load your Neural DSP presets onto your Pod. Using the Pod via midi might work but not sure as more info is required. Is the plug-in a stand alone one on your computer or is it one in a DAW? Jd Quote Link to comment Share on other sites More sharing options...
JohannDaart Posted August 16, 2021 Share Posted August 16, 2021 Loading presets from Neural to HD500 is an outlandish idea. Not possible. But you can use HD500 to send MIDI and Neural supports receiving MIDI. But then buying HD500 just to control Neural with MIDI is big overkill. On top of this, HD500 has old USB drivers that are not stable on most modern system's, so you would be better off buying some other MIDI controller with better drivers. Quote Link to comment Share on other sites More sharing options...
