Erno Posted August 21, 2021 Share Posted August 21, 2021 I have a Line6 POD HD500X and since a couple of days the Analog Chorus doesn’t work. When turning it off and on it doesn’t change the sound of the guitar not even if I set all the parameters of the chorus to maximum. I tried to roll back the Flash Memory and after that to reinstall the latest version, but it didn’t help. If I put the analog chorus in the effect chain in front of the amp it works perfectly, but it doesn’t work after the amp. My question would be if this could be a setup error, and if it’s the case, then how can it be fixed, or is my HD 500x just simply broken? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 21, 2021 Share Posted August 21, 2021 The Analog Chorus is a unique model on the HD series. The wet and the dry sounds are both panned to a side (I believe dry is left and wet is right). So depending on where the block is in your signal chain, it’s possible to not hear the wet sound. Quote Link to comment Share on other sites More sharing options...
Erno Posted August 22, 2021 Author Share Posted August 22, 2021 Thank you very much phil_m. You were right. There was the problem. It works in a stereo. Quote Link to comment Share on other sites More sharing options...
