USE OF LINE 6 S/PDIF OUT TO DIGITAL OPTICAL IN
ubiuankenobi
Good morning everyone. I would like to ask this question because I am a tad inexperienced and I know you guys are LIne 6 wizards. I would like to use some Sennheiser RS195 wirelss headphones with a DIGITAL OPTICAL IN. The Line 6 has an S/PDIF output (75-ohm with RCA connectors). How can I connect the Line 6 to the wireless headset if the ends of the two cables are different? Is there a specific cable or is there an adapter? Or can't I do it? I would be grateful for an answer. I wish you all a good day
Translated with www.DeepL.com/Translator (free version)
Hi SaschaFranck! Thank you so much for your response. I have a doubt though, using MISOTT would switch from Digital to Analog.... at which point I think I would just use the headphone output. I would instead use the digital output of the Line 6 and go into the digital input of the Sennheiser. Thanks again for your kind reply
Ooops, you're right, didn't look carefully enough.
And yes, the one from Thomann should be a proper adapter. You might be able to find a little cheaper one, though (I mean, you don't need it to be bidirectional).
And well, yeah, better search for "SPDIF coaxial optical adapter" - on Amazon, they start at €13 (no idea how good they are, but you can't do much wrong with those things).
