wynnphillips Posted December 15, 2021 Share Posted December 15, 2021 Hi, I'm stuck trying to set up a patch. I want to run my guitar in to the helix, then through a vrtual pedalboard of the usual suspects, ie distortion, compressor wah etc. Next I want to split the signal into two amps on different paths, onto delay and reverb (hopefully true stereo one amp to each side of the stereo effect. I next want to output that to my Seymour duncan powerstage 700 and yamaha stereo 2x12 which will be my stage sound, I also want to send the same signal through independent cab blocks and on to the xlr outs. I can't figure this out, if anyone could explain it to me, set it up for me or point me to somewhere I could get a patch with this setup I'd be gratefull. I intend to use this as my basic setup and so will be adding/changing individual effects for different patches. Thanks for reading and for any help. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 15, 2021 Share Posted December 15, 2021 Attached example preset. In Global Settings>Ins/Outs set the BIG KNOB (Volume Knob) to anything other than XLR. That will provide a steady UNITY (0db) signal to FOH. You probably want XLR Outputs set to MIC, but if the signal isn't hot enough change it to LINE. You probably want SEND/RETURN 1 and 2 set to LINE. If it's too hot for the SDPS, set them to INST. You'll use physical SENDs 1/2 for stereo to the SDPS. The MIX Block (after the amps) is panned HARD L/R. That puts your amps on separate paths. The Reverb/Delay are stereo, but in parallel because I don't like Reverb on every delay repeat, it gets muddy. After the Stereo Send 1/2 Block (signal to SDPS) there's a Dual Cab, which maintains your Stereo signal to FOH. There's no Stereo IR Block, so if you want to use IRs you'll need to put the Reverb/Delay in series, split the path after the SEND 1/2 Block, and use 2 IR Blocks with the MIX Block panned HARD L/R. EDIT: All amp and fx choices are more or less random, with stock settings. It probably sounds like a$$. wphillips.hlx Quote Link to comment Share on other sites More sharing options...
wynnphillips Posted December 15, 2021 Author Share Posted December 15, 2021 Thanks so much for that, I'll try it out tomorrow. Quote Link to comment Share on other sites More sharing options...
wynnphillips Posted December 17, 2021 Author Share Posted December 17, 2021 Hi again rd2rk that patch is great, good basis for me to build on. Thanks very much for your help. Quote Link to comment Share on other sites More sharing options...
