dacop13 Posted February 18, 2022 Share Posted February 18, 2022 I have a Marshall 2000 DSL head and use a TC Spark pedal in front of this amp. How should I configure this pedal into the Helix? I want to use the footswitch on the pedal to turn it on and off, not a switch on the Helix. Thx Quote Link to comment Share on other sites More sharing options...
adagosto Posted February 18, 2022 Share Posted February 18, 2022 That's super easy. I have the same pedal too. Its a hard one to replace. I really like it. But there's a question you need to answer first. As you know that pedal can be used in front of an amp as an overdrive OR you can place it into your effects loop. How are you wanting to use it? I assume from your post you also want to use it in front of the Helix amp models? If you want to use it as an overdrive, its very simple: Guitar --> TC Stark --> Helix Input. That's all there is to it. Turn the Spark on and off as you need. In my opinion, I find myself moving away from external pedals and the Helix (Stomp XL in my case). I really don't dig the sound of my physical pedals mixed with the amp models. I do have my amp connected via the 4CM and if I use my the Stomp with NO AMP model, then I'll use my physical pedals and supplement with models like compressors, modulation, delay and reveb. That's totally good. But mixing amp models, with physical pedals....not so much. That's just me and that has NOTHING to do with what you asked!! If you want to use your Spark in the loop, that's a bit different and then I need to understand if you are using the 4CM or not. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted February 18, 2022 Author Share Posted February 18, 2022 I use one in front for boost and one in the loop for lead boost. I have three of them! Two are just DB boosts and the other which is a gem has the Tre/Bass/Level/Drive, thats the one I use in front, in MID mode. Thanks!!! Quote Link to comment Share on other sites More sharing options...
