MK777 Posted March 2, 2022 Share Posted March 2, 2022 Hey everybody, I hope this is not a stupid question, but I'm facing the following problem and I'm not sure why. I've buildt the following signal chain on my stomp. My aim is to run my signal via the regular output and an IR straight into the mixing desk and to additionally use a poweramp into a cab on stage. That's why I split the signal before it goes into the IR. Now, when I connect the "Send" to the input of my poweramp all I get is a lot of feedback - nothing else. Am I thinking wrong when building the signal chain? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 2, 2022 Share Posted March 2, 2022 There's nothing in that picture that could cause feedback, but if you attach the actual preset I'll check it on my system. Meantime check your cables. You should be using a shielded TS cable (a guitar cable). Try a different one (or two). What poweramp are you using? Your SEND/RETURN L should probably be set to LINE. 1 1 Quote Link to comment Share on other sites More sharing options...
MK777 Posted March 3, 2022 Author Share Posted March 3, 2022 Thanks for your reply. I was able to fix it in the rehearsal room last night, apparently all 3 cables I tested it with are broken... that was an easy fix. Quote Link to comment Share on other sites More sharing options...
