Poly Sustain and snapshots question
ILikaGoFast
Hi all!
I love Eric Johnson, and wanted to try to create a preset with snapshots to be able to duplicate what he did on the intro of his first Instructional video.
In a nutshell, he begins with a clean tone with some chorus and delay, and switches between this tone and a high gain lead sound. He also uses an old MXR digital rack delay to create “infinite sustain” for playing a chord and letting it sustain, then switches back to his high gain lead setting to play over the sustained clean chords.
I am just learning how to use snapshots to try to recreate EJ’s switching possibilities.
Here then is my EXACT question:
How do I assign the FootSwitch control (along with the snapshot parameters,) so that I can switch back and forth between snapshots 1 and 2, with the Poly Sustain CONTINUING to repeat the clean chords UNTIL I want it to stop?
Is my approach below correct?
Snapshot 1 = Clean Chorus + Slight Delay (Poly Sustain ON, FootSwitch set to latching?) fx spillover set to ON
Snapshot 2 = High Gain, (Poly Sustain ON, FootSwitch set to Latching?) fx spillover set to ON.
I play the chord I want to hold out, on my clean snapshot. I press the assigned FootSwitch to engage it.
Next, I press the assigned button to go to snapshot 2.
When I want to go back to my Clean sound, I press the assigned button to go to snapshot 1. If I want to change the chord I’m improvising over, then I press the assigned FootSwitch to turn it OFF. I then do some chord changes, Melodies or whatever, and if I want to hold out another chord to do high gain leads over, I press the assigned FootSwitch button to ON and switch to snapshot 2.
Does this sound right?
Thanks guys for any help!!
