Problemas de impedancia en pod go.
luisriver
Se está montando mucho revuelo en las redes sociales con el tema de la impedancia del pod go y de los resultados en el tono al pasar la señal por un pedal buffer.
Sería interesante si pudieran dar alguna solución a este problema en futuras actualizaciones, los usuarios de pod ir se sentirían defraudados con los resultados obtenidos tras el descubrimiento de la falta de impedancia.
Les muestro algunos videos de los resultados:
There's been a lot of chatter on this and whilst I'm not suggesting there isn't a difference with a buffer, I do think this has all got a little out of proportion & is being over-hyped.  If you use cables and put a buffer in front of most MFX you'll likely hear a slight difference to top end.  Since Pod Go came out, customers have been singing its praises and its tones.  It's only over the last couple of months and since these 'tone-suck' videos, that suddenly some customers are unhappy with their tone and saying that the impedance value in one of the Pod Go FAQ's was incorrectly stated.
I use a Line 6 G10 Relay with my Pod Go, but I tried it with cables and although there is a slight difference in top end it's not devastating, and I get a similar variance with my Vox Tonelab SE, LE & ST units.  I think a lot of this has to do with your cables - I have Pirhana straight cables & a Vox coiled cable (all top quality)and they behaved very similarly.  You can add top end with some EQ adjustment, or if you prefer the tone with a buffered device in front, then go for it. Almost all Boss stomp pedals will be buffered, and wireless units like the Line 6 G10 Relay are buffered.
Unlike Helix, Pod Go has no option to select a different input impedance; it's unclear whether Line 6 might be able to do something here via firmware but if it is, Pod Go v1.40 is in development so it's at least possible this might be something that Line 6 is looking into.   However, in view of the amount of discussion on this throughout youtube, facebook sites and forum boards, and the reports to Line 6 support, I can only think that line 6 must be aware.  At this juncture I'm not aware that Line 6 has yet made any response on this and inevitably there may be some customers who might therefore be feeling some degree of frustration.
But if customers were enjoying their Pod Go's before then this really shouldn't be impacting on their continued enjoyment. There are some great vids & soundclips of Pod Go, including live use with cables, showing off some great tones - if there really was any serious issue I think this would have reared its head as soon as Pod Go came out and not some two years later!
I've just re-listened to the Pod Go launch demo by Paul Hindmarsh (great player) at Namm2020 - Paul uses cables - and I don't recall anyone throwing their hands up in horror complaining that Pod Go sounded bad with no top end!! lol
Buenas voxman55 , un placer leerte por estos sitios, precisamente nunca me he quejado con el tema de la impedancia que tan importante lo están haciendo otros, es algo que no le he dado importancia y de echo no voy a probar ningún tipo de buffer, mas que nada porque prefiero la libertad que me da el pod go sin necesidad de usar pedales externos.
Lo que, si me esta molestando es la cantidad de preguntas diarias en las redes y foros acerca de lo mismo, por eso este hilo que he abierto en este soporte de line6 es para que de una vez puedan dar una respuesta publica de las intenciones de line6 al respecto y poder calmar los ánimos de muchos usuarios con este tema, creo que seria un alago por parte de la marca que dijeran algo.
Ya sea una opción contemplada en actualizaciones futuras como si es algo que no pueden subsanar y no le den la mínima importancia, ya digo que para mi es indiferente, pero no parece la misma opción para otros muchos usuarios.
@luisriverIf my Google translation is working correctly, thanks for confirming that you personally are not bothered by this issue, and because you like the freedom of Pod Go 'as is' you are not interested in adding an external buffer.  But because of the sheer volume of posts on this around the internet, youtube etc, you feel it's important that line 6, regardless of whether this can be dealt with by firmware upgrade or not, should be responding on this to help calm all these posts down.
I've previously posted on 'the Gear Page' forum asking @Digital_Igloo(the handle for Eric Klein, the  Chief Product Design Architect for Line 6) if he might be able to make some comment on this that could be shared, for the very same reason, as I think he's really the only person senior enough to do so, but he's a very busy guy and only looks into some of the sites periodically so may not have seen this.
Ya sé que es difícil que vean esta publicación, pero es una manera de por lo menos intentarlo, quien sabe, quizás pueda llegar a sus oídos si algún moderador de este soporte lo cree conveniente o lo notifica por otro cauce mas interno, ya que los usuarios no tenemos otra opción, más que los foros y redes sociales.
Ya veo que lo has intentado y no has tenido respuesta directa, es una pena porque sigo creyendo que podría llegar a ser una falta de respeto por parte de line6 hacia los propietarios de uno de sus productos, entendiendo que sean personas muy ocupadas, pero esto es algo que podría repercutir en futuras ventas de otros productos.
Una marca no se hace grande y de éxito solo por su calidad, también el trato al cliente es muy importante y te lo digo como empresario durante muchos años.
El no prestar atención del asunto que tanto interés está suscitando, dice mucho en contra de una empresa, los usuarios necesitan una explicación.
Por ejemplo, hasta hace poco tiempo al entrar en la web de line6, automáticamente te aparece una información del problema del G10 de posible incendio, creo recordar, no veo que esto de la impedancia sea tan trascendente como para llegar a esa situación, pero unas sus palabras de creadores (ingenieros) al respecto, no creo que sería una mala idea y, quedarían todos los usuarios muy satisfechos con las explicaciones directas de la marca.
Bueno como ya te comentó, para mi no es algo relevante, pero si me gustaría conocer una opinión de la propia marca sobre todo este asunto.
