stevekc Posted April 6 Share Posted April 6 https://www.vguitarforums.com/smf/index.php?topic=34346.0#msg253960 GLOBAL SETTINGS Observe Global Settings panel above. The FX Loop is unity gain , with a straight patch cable connected from FX Send to FX Return , there is a -6 dB signal loss on FX Return when FX Loop is set to Power amp input and Loop is Engaged in the System settings Line-6 probably designed the FX Loop in this manner to accommodate higher output levels from external MFX outputs levels. But worth knowing FSW2 Assignment Options Quote Link to comment Share on other sites More sharing options...
